Not Charging
Old Nov 29, 2014 | 03:30 PM
TipTricky's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
Not Charging
Ok so i have a 91 TPI 350 and its not charging... The connector on the alternator has 12 volts on the red wire and 12 volts on the brown wire with the key on and then a wire from the out terminal to the battery but there is a black wire on my connector that is going to nothing... New battery, alternator is testing fine all 3 times, fuse for fan is good, and i cant figure this out any one have some advice?
Old Nov 29, 2014 | 04:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Not Charging
Who is testing the alternator?
Old Nov 29, 2014 | 04:39 PM
TipTricky's Avatar
Re: Not Charging
well auto zone and oreilley. I checked the voltage out of the alternator with a dvom and its 12.1 and drops slowly as it runs.
Old Nov 29, 2014 | 11:06 PM
TipTricky's Avatar
Re: Not Charging
No one has any advice on what could be wrong????
Old Nov 30, 2014 | 12:54 PM
TipTricky's Avatar
Re: Not Charging
Guess ill go run tests on a pick n pull car
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
