blinker indicator and high beam indicator
Old Dec 1, 2014 | 02:04 AM
STL_95's Avatar
Car: 1986 Iroc-Z
Engine: 5.0 Tune port
Axle/Gears: Stock? 2.73
neither work, replaced all the bulbs behind the spedo face, recently fixed the harness that connects from steering column to wire harness that leads out. so what should i check next for the blinker indicator and high beam indicator?. High beams work by the way. by the way my battery gauge or voltage gauge seems to move around a little but seems to hangout at 13 consistently, guess its just old?
Old Dec 29, 2014 | 03:34 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blue Light Special
OK because the Hi-Beams work we know the switch works.
The
light green wire travels from the output of the Hi-Beam switch to a connector in back of the dash.
Use a voltmeter or small bulb to see if there is power at the connector.
If yes, the problem is a bad “printed circuit” inside the dash.
Use the voltmeter or small bulb to see where the voltage stops.
When you solve the Hi-Beam indicator problem you can apply the same principles to the turn signals indicator problem.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
