1990 tail light harness
Old Dec 1, 2014 | 09:16 PM
faehndb's Avatar
How do I install the rear section of a tail light wiring harness for a 1990 camaro
Old Dec 29, 2014 | 03:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tale For The Tail
If it’s in good shape it should into place.
If not you can use a 12 volt fused source to probe which wire illuminates which bulb.
Just connect ground to ground
(black wires in most cases) then using the + wire from the supply, touch the unknown wires.
When the bulb illuminates, attach a label to the wire.
As far as the car you’re working on, if there is no taillight assembly on it at this time, you can find out what wires illuminate what bulb by using a voltmeter or clip on lamp then label those wires.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Jk_Under
Sep 2, 2015 10:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
