84 Z28 Tach help
Old Dec 14, 2014 | 05:16 PM
1984Z28ttop's Avatar
Car: 1984 Z28 L69
84 Z28 Tach help
Hey guys and gals, I am having an issue with my tach in my 84 Z28 H.O. car. Every time I start the car the needle spins all the up and just sits there until I shut the car off and go to start it again, then it spins right back up and sits. I have been thinking the tach itself is bad or the resistor is bad. Any suggestions on how to test or find out what it could be? I have had the same issue with 2 distributors, the stock and a vacuum advance distributor I installed when I swapped in my 350.
Old Dec 15, 2014 | 10:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 84 Z28 Tach help
Sounds like a wiring or internal tach issue to me. Double check all of your grounds under the dash and make sure your tach wire coming from the distributor isn't chaffed and grounding itself to metal somewhere.
Old Dec 20, 2014 | 10:40 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
https://www.thirdgen.org/forums/elec...meter-fix.html this works on all third gens.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
Racerx974
Sep 19, 2015 10:16 AM
TrevinE
Sep 14, 2015 03:20 PM
