Location of Voltage Regulator
Old Jan 23, 2015 | 11:52 PM
stalkier's Avatar
Engine: 5.7ltr
Transmission: 700r4 with shiftkit
Axle/Gears: LS 4.11
Hello everyone. I was wondering if you kind gents could point me to the location of the voltage regulator on an 88 trans am 5.7ltr TPI. I've only had the vehicle a few days and I am running into the issue with a bouncing speedo and lights that dim up and down. I know it can be a few different issues and I'm tracking them down one by one to work bugs out. Thanks for your help.
Old Jan 24, 2015 | 12:36 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Re: Location of Voltage Regulator
The voltage regulator is built into the alternator if it's bad it's time for a new alternator, I'm not 100% sure but I believe you should have a mechanical speedo, in wich case the power woulden't make it bounce, mabe someone ells can chime in and clarify when gm switched over
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
89fast5oh
Sep 8, 2015 09:55 AM
lakeffect2
Sep 7, 2015 03:52 PM
tonys91rs
Sep 2, 2015 07:07 PM
RyanJB
Sep 2, 2015 01:27 PM
