Dizzy type on a 1990 305ci
Hi, I was wondering what type of dizzy the 1990 305 TBI camaro had?
Doing a full megasquirt ECU conversion along with power upgrades and LPG (propane). Came across a website that was on about TBI/TPI dizzy having hei18 dizzy?
If so would make configuring timing much easier.
If not what cars came with them and is it hard to convert my
Dizzy to hei?
Thanks, Carl.
Dizzy to hei?
Thanks, Carl.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Dizzy type on a 1990 305ci
Dizzy to hei?
Thanks, Carl.
Dizzy to hei?
Thanks, Carl.
Now, I'll admit, I don't know anything about this HEI18 you're talking about, but a factory distributor from just about anywhere will serve you well.
I see, thank you for the information. Don't suppose you have any sources for your information? Just trying to find more out on the distributor but failing.
The project is for my final year at university (more power with the same running costs through use of alternative fuels and management)
Car: 1984 Trans Am
Where are you attending, if I may ask?
Try this:
http://www.pontiacpower.org/HEI.pdf
and
Delco-Remy
A little history of HEI...
Try this:
and
Delco-Remy
I'm attending at a University in the UK.
Thank you for the information, will have a read when home tonight.
Also apologises for any bad spelling, joys of using my phone and rushing.
Car: 1984 Trans Am
A good friend of mine just graduated with her PhD from Cambridge and is getting her thesis published. Kind of exciting. Best of luck to you in your studies!
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
