Chasis Ground
Old Feb 26, 2015 | 07:21 PM
dsebastian0127's Avatar
Car: 92 Camaro RS 25th
Engine: 3.1 V6
Chasis Ground
I believe I have a bad ground that's wreaking havoc on my electrical system. My battery to block ground is solid and clean. I've been reading that there should also be a ground to the chasis however I haven't found one so my question is where to put it. Should I piggyback it off of the block ground and then run it to the chasis? Please help. I've found tons of posts on grounds but I seem to be behind the curve because the posts are all referring to a chasis ground but no explanation of how to run one.
Old Feb 26, 2015 | 07:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Chasis Ground
You should have a Braded ground wire on the Right Side of the engine grounded to the Firewall.
Old Feb 26, 2015 | 07:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Chasis Ground
Old Feb 26, 2015 | 07:41 PM
Engine: 3.1 V6
Re: Chasis Ground
Thank you very much for your response. I found the cable it's there and clean. Was hoping that would be a fix. I did however find a ring terminal with two drk blue maybe blk wires coming out that is just hanging. I'll see if I can get this pic upload to work.
Old Feb 26, 2015 | 07:42 PM
Engine: 3.1 V6
Re: Chasis Ground
Location of the ring terminal comes out of a thick harness right behind the distributor cap. http://imgur.com/0DDtlN8 sorry I know this is off topic now just at a complete loss.
Old Feb 27, 2015 | 11:18 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Chasis Ground
Should also have a ground wire leading from the battery cable connection to the body, The factory wire should lead away from the battery terminal connection and gets screwed to the body/frame near the battery.
Old Feb 27, 2015 | 11:21 AM
Engine: 3.1 V6
Re: Chasis Ground
Definitely missing that one. I'll have to add that today. Thank you.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
