Speedo not working - Wiring questions VSS etc.
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi all!
I have almost completed my Holley HP Efi conversion. One last problem remains.
My Speedo is not working anymore.
I have converted from TH700 to T56 , and have a Dakota Digital SGI-5C which worked well so far (just some interferences which let the speedo needle jump back and forth ).
With the stock ECM i see that there is a brown wire going from the vss speed buffer to ecm port A10 , which should be the ECM input for the speed signal.
Do I need this wiring in order to have the speedo working? At least it seems so.
Can anyone help me with that?
Thanks alot
Alex
Thanks alot
Alex
Car: 89 Camaro Rs 350
Re: Speedo not working - Wiring questions VSS etc.
Same problem here just had my 305 swapped out for a 350 and none of my gauges work researching how to properly install each
Problem is not resolved yet but it seems that I accidently have cut one of the wires going to the C207 connector ( one of them should be the wire thats leading to the speedo )
As far as I know it won't be necessary to have the vss input for the ecm, this is just for logging, not for controlling anything besides a speed limiter.
beachrodder
Aug 7, 2015 04:27 PM
