Headlights Still not working
Car: 1984 Camaro Z28
I just replaced my headlight switch this afternoon and my headlights worked fine...for about 5 minutes then they began to flicker. The will go on and off repeatedly and I can't figure out the problem. Need some help
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Your New Lights R Not Right
There is a circuit breaker in the headlight switch.
That is what is causing the flashing, it can be defective even tho new, or something in the headlight circuit is drawing too much current.
Make sure you are using correct original type headlight replacements and not aftermarket gimmicky or “brighter” headlights.
Happy Racing !
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Happy Racing !
Transmission: 765R4
Heads Up
Yes.
To verify, use an ammeter in series with a stock type replacement and note the reading.
Then test your new headlight(s) the same way, all prongs, the dim and the bright filaments, to see if they draw more current.
Happy Racing !
Happy Racing !
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
