Wiring for alt
Old Mar 19, 2015 | 07:39 PM
stalkier's Avatar
Engine: 5.7ltr
Transmission: 700r4 with shiftkit
Axle/Gears: LS 4.11
Wiring for alt
Hey guys/gals. I have a 1988 Trans am with 5.7 TPI. When I got it the wiring as all messed up from people messing with it over the years. I am getting feedback in the charging system right now. I am wondering. There is a plug with 3 wires and another plug on the back for 1 wire. How does this need to be wired? I currently have it wired with a new pigtail for the 3 wires, to their respective colors, and the 1 wire is going to the battery. Is this correct as far as the one wire? I was told on Camaro and Corvettes that there is a distro block or whatever that wires go to and then feed to the battery. Mine does not have this block.
Old Mar 19, 2015 | 07:45 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Wiring for alt
Old Mar 19, 2015 | 07:49 PM
stalkier's Avatar
Engine: 5.7ltr
Axle/Gears: LS 4.11
Re: Wiring for alt
Originally Posted by mantaguy
this is no need for photos. There are 2 plugs on the back of the alt, a 3 wire-pigtail and a single wire with a rubber boot so it doesn't touch the valve cover. The single wire is going to the battery. The pigtail is wired into the wiring harness.
Old Mar 19, 2015 | 09:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Wiring for alt
O,OK,you didn't mention it was the alternator in the 1st post.Yes,your wiring is correct.
Old Mar 19, 2015 | 09:14 PM
stalkier's Avatar
Engine: 5.7ltr
Axle/Gears: LS 4.11
Re: Wiring for alt
Thank you sir
Old Mar 19, 2015 | 09:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Wiring for alt
Originally Posted by stalkier
Thank you sir
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
armybyrd
Dec 5, 2015 09:22 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
