Removing wiring (Easy help)
Old Apr 2, 2015 | 10:11 AM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Removing the wiring for ac, heat and AIR system. Will that cause any issues? The actual components are removed currently, and since I have ceased needing the wiring, I want to remove it's clutter and extra weight.
Old Apr 3, 2015 | 09:40 AM
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Re: Removing wiring (Easy help)
If you have electric fans, and if they're hooked up through the stock wiring, they won't work anymore once taking that harness out. Pretty sure that's it though, unless GM changed up some of that climate control harness in 89.
Old Apr 3, 2015 | 10:07 AM
killer777's Avatar
Engine: 355
I do have electric fans. Would you possibly know how I would need to wire the fans up then?
Old Apr 3, 2015 | 10:17 AM
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Do your fans turn on when you turn the AC on? If so, then there is a green wire that comes out of the harness for the whole AC system and goes to the fan relay. Just cut that wire from the AC harness and put a switch on it that sends it to ground.
Old Apr 4, 2015 | 04:14 PM
killer777's Avatar
Engine: 355
Thanks so much 84LsxZ28. Your help was much appreciated.
Old Apr 4, 2015 | 07:52 PM
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
No problem, very glad to help
armybyrd
Dec 5, 2015 09:22 AM
mhatfield 14
Aug 15, 2015 10:47 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
