problems with charging
My 92 tbi 305 auto trans is messing up. Went to Walmart came out and the car wouldn't start . First thought is alternator .. jump the car.. limp home.. next day alternator comes off and auto zone tests it .. it pass's 3 times in a row . They switch it out anyways and test that one and it passed alternator goes back on .. I do a alternator check with a battery charger and it says alternator bad or engine not running which the engine was running . Battery is 6 months old .. where would you start ?
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: problems with charging
i would check the fuses ... when i started up my gta for the first time i had no charge ... one fuse was gone out of the box, and it was the one to turn on the alt for charging
GeneralIesrussi
Sep 3, 2015 03:23 AM
