Fuse Box Wires are loose !!!
Old Apr 11, 2015 | 03:37 PM
Derrickum's Avatar
Car: 1989 Camaro
Engine: 2.8
Transmission: 5 Speed Manual
I just bought a 89 Camaro RS 2.8 and it hasn't been ran in awhile. I was cleaning up the interior and saw 2 wires just hanging near the fuse box. I need to know where it's supposed to be plugged in. Both are skinney , one is solid orange and the other is solid white .
Old Apr 11, 2015 | 06:32 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Fuse Box Wires are loose !!!
Those wires used to connect to a small (#194 bulb) courtesy light that was in the underdash panel and lit up the footwell when the interior lights were turned on . If you don't want/need a light there , tape em up good so they won't short and call it done ....
And , welcome to the forum !
Old Apr 12, 2015 | 03:22 AM
Derrickum's Avatar
Car: 1989 Camaro
Engine: 2.8
THANK YOU SO MUCH! I'm happy I joined, this car needs work and some stuff I just can't figure out alone. Got another question, I also found a connector near the fuse box that is unplugged and another black connector just hanging. Any idea what they do?
This one is very short
This one was right under the steering column.
Old Apr 12, 2015 | 07:28 PM
OrangeBird's Avatar
Car: 1989 Firebird
If you can tell me the exact colors of the wires going to those disconnected plugs , I'll look at the wiring diagram and see if I can help you identify them . I will admit , I've seen most of what's under the dash of my firebird , and I don't recognize either of them . In picture two , it kinda looks like it could be the cruise control connection that would run from the steering column to the dash's harness (running from the switch on the turn signal to the dash wiring) but this is only a guess since I can't too clearly see the connector .
Old Apr 12, 2015 | 11:10 PM
Derrickum's Avatar
Car: 1989 Camaro
Engine: 2.8
My 89 is manual so no cruise control. Right? And I will check the colors in the AM. I spent all day cleaning the acorns outta the car and messing with the VATS system. (I hate it) fortunately I read a couple articles here and I bought a vats resistor packet off eBay. The owner before me lost the key and decided to drill out the key cylinder in hopes of it turning over (He wasn't very mechanical savvy). Also have to install a distributor rotor and assembly. It was missing when I bought it. Will need help retiming
Old Apr 13, 2015 | 01:17 PM
Derrickum's Avatar
Car: 1989 Camaro
Engine: 2.8
One wire is brown and the other is gray with a white line
Old Apr 14, 2015 | 05:59 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
89 2.8
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
http://austinthirdgen.org/mkportal/m..._continued.gif
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 13, 2015 12:59 PM
