90 firebird tpi to tbi conversion.
Old Apr 15, 2015 | 02:25 AM
poeboy's Avatar
Car: 1990 Pontiac firebird formula
Engine: 305 tbi
Hello, I am new to this forum. I have a 90 formula that was originally a tpi 305 converted to a tbi. So far it is running good but my speedo does not work. I need to install a vss buffer as the tpi had one in the ecm? Can anyone help with this? Any help is greatly appreciated! ! Thanks. The reason for TPI to TBI was a ton of issues related to TPI. Knock sensor, Fuel, and timing just to name a few. Does anyone know where I would add the VSS Buffer and which buffer is needed?
Old Apr 18, 2015 | 12:50 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: 90 firebird tpi to tbi conversion.
I would swap back to TPI, but each his own.
read this (is not a guide, but will help you grasp the concept)
https://www.thirdgen.org/forums/elec...-odometer.html
Find a buffer box out of a 90-92 f-body, make sure you get the connectors with it. When you have the buffer and you have read the thread above, if you still have questions came back to this thread and I will help you.
BRoss99
Aug 10, 2025 05:08 PM
xkingcodex
Feb 12, 2020 07:43 PM
justin57
Aug 20, 2015 07:05 PM
Randomtask2
Aug 13, 2015 01:57 AM
Sanjay
Aug 12, 2015 03:41 PM
