Odometer has stopped !
Old Apr 21, 2015 | 11:57 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
And i know why....ever since i done the engine swap things have been affected, i went from a 5.0 TPI in my 87 GTA, to a 5.7 TPI from another 87 GTA, but a hardtop and i think possibly the donor car had a digital dash, and mine has the analouge one so theres probably a few differences.
Anyway the speedo and odomter stopped working and it was crossed wires from the engine bay to the speed buffer causing the speedo to stop working so my friend sorted that, but he couldnt trace the wires that make the odomter work, he assumed they would be shared with the speedo but obviously not.
Any ideas ? id like to keep my cars mileage counting up, its missed a few hundred miles now already
Old Apr 21, 2015 | 12:05 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Odometer has stopped !
You may have suffered the dreaded crumbling gear problem I have seen in a few of these cars. For some reason, 1 gear in the speedo that runs the odometer and trip odometer just turns to dust....
Old Apr 27, 2015 | 08:59 AM
raptor427's Avatar
Car: 1987 Trans Am
Engine: 305 cid
Transmission: 5spd T5 BW.
My gear motor actually froze, so I ended up having to find a new speedo/odometer set..
Old Apr 27, 2015 | 10:29 AM
gta_knight's Avatar
Car: 1987 GTA
Im pretty sure its electrical. both the speedo and odometer were working perfectly before the engine swap, then afterwards nothing. We ran new wires from the speed sendor and the speedo is working again.
Im just not sure where the wires are for the odometer
Old Apr 27, 2015 | 06:14 PM
lakin454's Avatar
Car: 88 Firebird Formula
Transmission: WC T5
Axle/Gears: 9 Bolt 3.45
I did a motor / trans swap and the car sat for a while, the Speedo wasn't hooked up when it finally got running. When I tested the cluster on another car the speedo worked but not the odometer. Come to find out the gear the little motor drives froze up and chipped off part of a tooth. I carefully got the gear loose and lubed it up. It works now despite a partially broken tooth.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
