Runs fine when cold, dies when warm! Please help!
Old Apr 27, 2015 | 11:57 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Will start and run when cold, idles fine, warms up and starts to pop at idle and run rough. If you shut it off it won't start again for 2-3 hours if it does start it runs like above. Rough. No codes thrown. Injectors are not pulsing correctly on a scanner. I put in a new distributor, didn't fix it, checked the computer. Didn't fix it. What else can cause this? It's a 92 tpi 350 z28. Now going through wiring to distributor and on the car to see if it's a wiring or ground issue. I need it fixed fast.. Any ideas?
Old Apr 27, 2015 | 12:56 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Runs fine when cold, dies when warm! Please help!
Can you check your sensors with the scanner. You should look at your cts to be sure it's not flaky when gets hot. You might be onto something with grounds though, check all those too.
Old Apr 28, 2015 | 09:15 AM
Axle/Gears: G92
Sensors seem fine.. Still lots to check.. Looking for more ideas..
Old Apr 28, 2015 | 11:12 AM
Axle/Gears: G92
It's the injectors apparently... They aren't ohms correctly.. 5 out of 8 were below 16. 3-4 were 5.. One was 1.
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
