84 berlinetta cranking problems
I recently acquired an 84 berlinetta that won't crink, the motor has been swapped from the original crossfire to a carbureted 305. I haven't really had time to really look at this car much, but I have begun to realise that whoever was the previous owner liked to jerry rig things into place. For instance the steering wheel has been replaced by a steering wheel out of a firebird.
Onto my question, When I turn the key to the start position, nothing happens. no solenoid click or anything. I was looking at the fuses, and the crank fuse is non existent, not even the metal tabs that hold it in place. Could this be the root of my problem, if so how should I go about fixing it? Any other leads on where to look would be appreciated! Thank you
Re: 84 berlinetta cranking problems
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The CRANK fause was used with all fuel injected cars.
The only Factory carburated cars with the CRANK fuse in the fusebox were "HO" Z28's with a factory installed in-tank fuel pump. ( IIRC - possibly some 87's too. )
Hey, update: Traced ignition wire and neutral safety switch wires, had signal...went to hitting on starter, motor turned a little. replaced starter and battery and now the motor runs like a top
thank you guy so much!
thank you guy so much! Thread
downsouthboy
Aug 29, 2015 11:29 AM
355tpipickup
Aug 27, 2015 08:13 AM
