Power windows cause motor to shut off?
Old May 1, 2015 | 12:56 AM
bluebomber11's Avatar
Hey all,
I bought a 1992 Formula 3 days ago with 72000 original kms. Anyways, today, I rolled my power windows down, and when i went to hit the switch to bring them back up again, the engine shut off. I drove the car earlier today with the windows down and brought them up no problem. I tried a few times to bring the windows up, but every time it was like the motor was stalling out. How is it even possible that the windows effect the engine? Does anybody have any ideas what caused this and how to possibly fix it? Thanks, Phil
Old May 1, 2015 | 10:58 PM
Kingbambino22's Avatar
Car: 1992 Camaro
Engine: 1992 TPI 350
Axle/Gears: 1992 stock 3.23
Re: Power windows cause motor to shut off?
I had the same problem today. When I attempted to roll the window up it caused the engine to bog down after I had the window motor replaced. I pulled the door panel off and found out that the wire had part of the metal exposed. Once I taped the wire up. The window works fine now. It was a short in the wiring. So I suggest check the wire that controls the window motor. Hope that helps.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
armybyrd
Dec 5, 2015 09:22 AM
stalkier
Aug 13, 2015 12:59 PM
