Highest Fan Speed not working
Old May 1, 2015 | 05:05 PM
777Shock777's Avatar
Engine: 5.7!
Hey everyone, on my 88 GTA the highest fan setting does not work.
Everything else does - A/C, Heat, etc, I just can't get the highest fan setting to work.
I keep reading bits and pieces about the high fan setting yet can't seem to find any solid answers or pictures of where/what it looks like.
I'm guessing this is my issue and I just need a little help, any part numbers or pictures would be much appreciated!
(This is the digital dash/digital HVAC control)
Old May 2, 2015 | 05:38 PM
Engine: 5.7!
Re: Highest Fan Speed not working
I just want to reference this thread since its been a HUGE help, I found the location of the high speed relay, and have ordered a new one from ebay! (Rockauto, autozone, etc. don't seem to stock it anymore).
https://www.thirdgen.org/forums/elec...-resistor.html
EDIT: I'll upload my results after I replace the relay, hopefully it fixes the high speed fan not working...
The next thing on my list is to replace the weird power wires mentioned in that thread.
Old May 4, 2015 | 01:42 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Before you install that new relay, check out this connection. Its for the blower motor HIGH SPEED ONLY. It's located along the firewall at the end of the passenger valve cover is. Around that location. THESE CONNECTORS ARE NOTORIOUS FOR SHORTING OUT. Check your's out. If its chrispy, cut the connector out and eliminate it. Tie the two wires together with weatherproof wire nut or somthing.
Old May 8, 2015 | 01:34 AM
Engine: 5.7!
Thanks for the reply! - I found a relay for cheap from a dealership selling off their old inventory and the high speed still does not work after replacing it.
I checked the connection and you are right! Its totally got some gunk/melted plastic on it, so I'm going to cut those out tomorrow and hope that resolves it
Old May 10, 2015 | 09:17 AM
Engine: 5.7!
That was the problem that caused my high fan speed to not work
Thanks!
Old May 10, 2015 | 10:20 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Does the high speed not run the fan at all? Or is it just not running it as fast as you feel it should?
Old May 10, 2015 | 10:47 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
With the Fan switch on high, and the connector that is mentioned, controls the High speed. If its bad, fan will not work.
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
