installing LC-2 controller and WBo2 sensor
Old May 10, 2015 | 10:46 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
looking to hook this setup up but I was kinda confused on wiring, is there a spare circuit that has juice with the key on that can support amperage draw I don't figure it would be much the control takes 3 amps not quiet sure on the gauge. then I figured I would ground both the gauge and controller to the same ground probably the bracket that there steering column mounts to then from the controller there is a brown and yellow one goes to the gauge and the other to the ecu (purple wire right) does it matter which one goes where? and what wire go I use for the dimmer wire on the gauge?
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
nuggie
Aug 25, 2015 01:27 PM
