no electronic signal to distributor
Old May 3, 2015 | 06:59 PM
aparks760's Avatar
Car: 1986 pontiac firebird
Engine: 305 v8
i have a 1986 pontiac firebird base. it has a 305 5.0 v8, that uses a 4bbl carb. the car wont start, and i have gone to the conclusion that the distributor does not get any electrical signal. i have checked my fuseable links, changed my coil, changed my computer and nothing has changed. please help!
Old May 3, 2015 | 07:38 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: no electronic signal to distributor
CCC HEI only needs 12v power to it to spark-the 4-wire plug to ECM harness only controls spark advance-if it is getting 12v feed and coil is new/good,pretty much leaves a bad pickup coil or ignition module as probable cause of no spark-bad ICM much more likely than bad pickup coil.
Old May 3, 2015 | 09:37 PM
aparks760's Avatar
Engine: 305 v8
i replaced the ICM, still didnt work.
Old May 9, 2015 | 07:04 PM
jcat's Avatar
Car: 96 Impala 84 berlinetta
Transmission: 4speed auto
place a timing light on it and while shooting the timing marks see if its flashing and hits the timing mark correctly 6 deg BTDC...when someone is cranking the engine.
check for 12 volts to dist.
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
