Blower motor doesnt blow on high
Old May 8, 2015 | 03:16 PM
havacamaro's Avatar
Car: 86 camaro iroc z
Engine: 355 LT1 Full Roller
Axle/Gears: 9 bolt 3.73 posi
Got a new blower motor and a new control switch, but when I put it on high it stops blowing air. Any ideas? on an 86 Iroc
Old May 8, 2015 | 05:58 PM
nova983's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.70
If you look by the blower motor there is a relay located there. It is the hi speed relay. You should check to make sure you have power and ground. I dont remember what pins are what off the top of my head. I am away on a trip or i could find out. If power and ground is good then probably a bad relay. That is what mine ended up being.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
