Fuse box, accidently removed fuse
Old May 11, 2015 | 08:18 AM
Misinko's Avatar
Pontiac Firebird -1991 TRANS 5.0 L
So bascially I opened up the fusebox and the yellow wire was very loose. Ended up removing both red/yellow and now I can't rem where they should be. The engine goes up to 500 rpm or hardly start.
Why I checked them from the start is because the car is having problem with stalling, etc. I'm not sure if this has affected it or not but any idea where these 2 cables originally should be?
Dumb me... Help
Fuse BOX (are the red wiress correct)?
A -1999 Firebird
Old May 11, 2015 | 11:41 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Fuse box, accidently removed fuse
Those two wires are for aftermarket stereo or other add on.
Old May 12, 2015 | 06:29 AM
Misinko's Avatar
I tried to play around with those and if I remove yellow away from IGN the car wont work at all. Can't even crank it
Old May 12, 2015 | 06:35 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Well it ain't stock/factory. Follow the wires and see where they go
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
snowflake
Oct 19, 2015 10:24 PM
3rdgenparts
Aug 8, 2015 07:09 PM
