VSS for 1992 manual trans
Old May 11, 2015 | 05:15 PM
triplec's Avatar
I've been searching for a VSS GM part number 10456087. It is a discontinued part and I cannot find anyone with one in stock. Any ideas on what might have to be done to get a working speedo? Tail shaft swap? Is there a way to modify an auto trans sensor? Thanks!
Old May 11, 2015 | 06:22 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: VSS for 1992 manual trans
I found a good used one on ebay. It sux, but that's probably your best bet. Either that or get lucky finding one in a bone yard.
Are you sure your VSS is bad? You can bench test it with a power drill and a multi-meter to rule it out as being bad. If it shows life with the bench test then you probably have a gauge problem. Oh and a bad VSS usually throws an SES code too.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
