Cranks with no start
Old May 23, 2015 | 12:49 PM
jsweatt's Avatar
Car: 1992 Camaro Z-28
Engine: 355
Transmission: Custom 700-R4
Axle/Gears: Stock 4th gen
I'm not sure if this is in the correct thread, but my 92 L98 cranks with no start. I have a Tech II and it shows 0 rpm when cranking.
Where does the rpm signal come from? I pulled the distributor cap and found what looks like excessive rust around the stater. Also, the outside ring has slack and can be turned about 1/8 a full circle. Is that normal?
The car was doing its weekly run in the garage and it just suddenly died. Luckily I wasn't on the road
There are no trouble codes.
Thanks for any input.
Jamie
Old May 26, 2015 | 04:22 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A Tach The Problem
Your tach wire needs to go to the PRIMARY of the coil.
The tach wire goes from the PRIMARY non-key side of the coil, to the firewall connector, to the dash connector, to the tach.
It’s a WHITE wire.
At the dash the tach wire is in the right hand connector, pin 7.
Is the engine getting spark?
Happy Racing !
Don’t Fuss Paintin’ Your Back Bumper, Cause B4 The Race Is Over I’m Gonna Be Pushing You Out Of The Way
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
