Dash lights mystery….
Old May 30, 2015 | 01:34 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I've got an '83 SE with an LS1. Got most of the bugs worked out. Nice car.
Here's a link, for anyone who wants a look.
https://www.thirdgen.org/forums/ltx-...u-gets-c5.html
I've got Autometer Tach and Speedo. Both work fine. Put them into my '83 dash, and those remaining gauges work ok, too.
What does NOT work is the dash lighting. No dimming feature, and if you go with the one setting that will work, everything goes out after 5 minutes. (circuit overheating?)
Changed over to '85 front plastic for my dash. Like the look better, much better. Thumb wheel dimmer is part of Headlight switch on the '83. On the '85 the Dimmer Wheel is moved to below the Headlight switch.
IS THE PROBLEM-
1) The Thumb Wheel switches are different, and the '85 won't work with the simple '83 dash lights (just a few small bulbs)?
2) The '85 Thumb Wheel switch is no good?
3) The Autometer gauges don't want to play nicely with the '83 gauges?
4) Something else??
Thanks for any info or ideas…..
Old May 30, 2015 | 03:33 PM
Re: Dash lights mystery….
If memory serves the Birds have a "dimmer module"... you probably need a new one.
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
