Charging issue?
Old Jun 7, 2015 | 11:43 PM
390v8's Avatar
Charging issue?
My friend was out in his car tonight and was driving back from work. He had dim headlights so I told him to shut the stereo off. Like a dumbass he decided he needed to get into a race. I guess now he is stuck and his car will not go over 20 miles an hour and the headlights are really dim. Is this an alternator that just gave out?
Old Jun 8, 2015 | 07:05 PM
390v8's Avatar
Re: Charging issue?
Just for some info. Alternator tested good and put a new battery in, still not charging. Any ideas on where the problem could be happening? 87 Firebird
Old Jun 10, 2015 | 10:30 PM
Jonny45's Avatar
Car: 1988 Firebird
Engine: Built 3.4 swap
Transmission: worldclass T5
Axle/Gears: 3.23 28 spine posi with moser axles
Re: Charging issue?
there are a few fusible links around the starter that could possibly effect that
Old Jun 12, 2015 | 01:04 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Charging issue?
How is the wiring from the alternator to the starter and into the harness? check for corrosion, bad connections and anything else that looks weird.
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
Slush92RS
Sep 2, 2015 08:56 PM
