Power Window Kit install
Old Jun 12, 2015 | 10:32 AM
Fechin's Avatar
Car: 1989 Chevy Camaro RS
Engine: V6, 2.8L Fuel Injected
Transmission: Manual, stock
Hello all!
This is a quick picture guide on how to install the EXPRESS UP AND DOWN kit from: https://www.thirdgen.org/forums/inte...relay-kit.html
Since I was going to power windows, here is also the steps for the regulator swap: http://www.idmsvcs.com/2vmod/thirdgen/powerwindows/
Formula1LE did a great job with this kit and I wanted to share the quality as well as the way I put this understandably large kit into my center console area. Also, if you were like me and were doing the switch to power.. I suggest this kit for saving lots of time...
1st set of pictures: http://s284.photobucket.com/user/swd...SS_UP_DOWN_KIT
This shows what came with my kit. I also wanted a relay and connector for my hatch release switch I plan on installing as well. This kit looked great. All it needed was a couple zip ties for placement in the console!
2nd set of pictures: http://s284.photobucket.com/user/swd...ow_Kit_Install
This shows the steps I took and where I placed the kit.
This worked for me, hopefully my radio unit will fit (should / need a new one) ... I hope this works for you as well as helps with your install!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 13, 2015 12:59 PM
