Fuel Guage problems
Old Jun 13, 2015 | 06:29 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Fuel Guage problems
I started to change out all of the lights in the dash for leds. I started out by taking out the tach, amps, fuel, and the temperature gauges. After I got done, I put them all back in. They all work except for the fuel guage. Whenever I turn the key the needle moves all the way up to the top of the guage. Any ideas?
Old Jun 13, 2015 | 06:36 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Fuel Guage problems
while a chore but not hard id say take it back out n make sure you didnt fold up anything while putting the cluster back in..n make sure its making contact correctly in the cluster plug. when i pulled mine out to replace it my temp didnt work..removed it n re-seated it everything worked..
Old Jun 13, 2015 | 08:07 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I took it back out and found out the ribbon wire was snapped. Any idea on how to fix it?
Old Jun 13, 2015 | 08:16 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
ouch...
junk yard..
iv never tryed to repair one by hand as if u tryed to u could screw something else up or cause something to melt or all around stop working.
Old Jun 13, 2015 | 08:22 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Old Jun 13, 2015 | 08:24 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
if that is a solid wire kinda thing, can try soldering it
Old Jun 14, 2015 | 07:28 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Solder a small jumper wire to make connection then use small amount of hot glue to hold in place........piece of cake
Old Jun 14, 2015 | 11:13 AM
^^^ This ^^^
A single strand of wire out of about a 18 gauge stranded wire is just about perfect.
Old Jun 14, 2015 | 11:33 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I've done a similar repair but needed to sand the trace a bit to get the solder to stick. If you can tin the surface of the trace before soldering the wire patch -all the better.
That circular discoloration is odd, how does the rest of it look?
Old Jun 14, 2015 | 12:24 PM
OrangeBird's Avatar
Car: 1989 Firebird
One quick bit of advise here ;
If you've never soldered before , this is NOT a job for a novice solderer !
Every bit of advise the guys here gave is 100% spot on , the repair is a small piece of wire soldered across the broken section . Yes indeed the area where the solder is expected to adhere must be gently scraped of the coating till bare copper is showing . Now here's the part , the copper is literally paper thin and backed only by the plastic that you see the rest of the ribbon conductor is made of , and this plastic will melt , shrink , curl and distort , and pretty much do it's best to thwart the attempted repair when the heat is applied to it . I have repaired these exact breaks and the key is really cleaned surfaces , and the shortest possible application of heat , just enough to properly flow the solder but not so much to curl the plastic . It's literally tenths of seconds between a working repair and a do over , the line between soldered and melted away being that fine .
Old Jun 14, 2015 | 12:28 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I'm only 16 and have never solderer before but my dad has done it multiple times.
Old Jun 14, 2015 | 12:49 PM
OrangeBird's Avatar
Car: 1989 Firebird
Cool , if your dad has soldered before , he should be able to repair this . Make sure to remind him , the piece of copper wire used as a jumper need not be very big , thickness wise , the bigger it is the more heat it'll take to flow the solder (with a greater risk of melting the plastic) . You should watch what he does , owning an old car makes soldering a good skill to learn .
Old Jun 14, 2015 | 10:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Like others have mentioned, soldering on a gauge cluster printed circuit can be an exercise in futility.
While expensive (because of the silver content) you can use a 2-part conductive adhesive to connect the jumper wire to the trace on the printed circuit in lieu of soldering.
Old Jul 3, 2015 | 03:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I'm a bit late to the party, but you could also try a window defroster repair kit. It comes with a small bottle of conductive paint used to repair broken rear window defroster grids. Just clean/scrape the ends of the trace and carefully paint a new trace. Just wanted to post this in case someone else comes along in the future looking to do the same kind of repair.
Old Jul 3, 2015 | 03:33 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
We ended up just soldering it back together. Thanks for all the info everybody.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
