1991 T/A 305 TPI cranks but no start
Was starting and idling fine and then it stopped wanting to fire up. It just cranks and doesn't try to start. Fuel pressure at 40-45 at rails and I have spark at the plugs. The injectors won't open up and allow fuel into cylinders.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: 1991 T/A 305 TPI cranks but no start
Get a noid tester and test the injectors.
Stock ignition?
Check the ohm's on the coil.
You may have spark off the wires, but it may not be strong enough to jump it once you have it with compression in the chamber
Stock ignition?
Car: '91 GTA
Engine: 421sbc
Not sure how much on a stock coil.
But on a MSD blaster SS coil(like I got) it has 4.4 ohm's when new
Sanjay
Aug 12, 2015 03:41 PM
