89 formula will not start all the time
Old Jul 3, 2015 | 05:28 AM
bobs89's Avatar
Car: 89 formula
Engine: 305 mpfi
Transmission: Automatic
I bought an 89 formula with 35000 miles on it and having a starting issue. The car sat for 2 years and when I picked it up I drove it home 250 miles. The next day it started running rough and would not start every time. I had new injectors put in and it's running great but still will not start all the time. It will start 3-4 times then after it sits it won't start if just cranks over. Let it sit again and it will start right up again but only 3 or 4 times then back to not starting just cranking over. Any help would be appreciated. Thanks
Old Jul 3, 2015 | 11:47 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: 89 formula will not start all the time
cap and rotor? low fuel pressure bad fuel pump or clogged filter?
Old Jul 3, 2015 | 12:49 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Ignition control module?
theshackle
Mar 5, 2017 06:37 PM
armybyrd
Dec 5, 2015 09:22 AM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
Randomtask2
Aug 13, 2015 01:57 AM
86Base
Aug 8, 2015 01:34 PM
