instrument panel lights not working
Old Jul 17, 2015 | 11:06 AM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi all, any help appreciated in advanced!
I removed my instrument panel to replace empty bulb sockets that I guess the previous owner removed. Before I replaced the bulbs, I grounded the socket to make sure they worked, and they did (with the key on). At the time the "shift" light also was working(manual trans). When I placed back the IP, the bulbs do not come on including the "shift" light. I grounded the socket, and they are getting current. I tried different bulbs and do not come on. The only light that do not work on the panel are the choke, service engine soon, and the shift, all 3 in the RH of the panel. All others work.
Any suggestions will be appreciated!
Old Jul 17, 2015 | 01:04 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: instrument panel lights not working
Remove the cluster again and trace the ground circuit that you used to apply ground and check to see if all those lights share the same ground circuit.
My guess is that the printed circuit has failed and the "common ground" circuit is bad.
Old Jul 17, 2015 | 06:06 PM
podiatra's Avatar
Engine: 350 swap
Do you mean with "printed circuit" the map like wiring stuck to the IP?
Old Jul 17, 2015 | 09:02 PM
podiatra's Avatar
Engine: 350 swap
Actually I found the printed circuit in the service manual.
Old Aug 15, 2015 | 02:26 PM
podiatra's Avatar
Engine: 350 swap
So, I must returned to the thread... I got the IP lights to work except service engine light which does not come on when with the key in "on" position. The light bulb socket does have power per my multimeter. Can it be something else? I read in a thread that there is "CEL" type relay or something along those lines in early version of these cars, and that the service engine light is not control by the computer but by this relay.
Old Aug 15, 2015 | 07:44 PM
John in RI's Avatar
The Carbureted cars got something called a "Lamp Driver" that was used by the ECM to control the Check Engine light. It was mounted on the dash harness - not easy to access but it can be done,.... Here's a picture:
I might still have a few of these hanging around; if you need one - send me a PM for info !
Old Aug 26, 2015 | 11:27 AM
SKIDOG74's Avatar
Car: 91' RS CAMARO
Engine: 305 V8
do you have a copy of that? I am having trouble with my panel too. I finally got the shift light to work and vent lights to work.
Old Aug 26, 2015 | 07:46 PM
podiatra's Avatar
Engine: 350 swap
Hope it helps!
Old Aug 27, 2015 | 09:34 AM
SKIDOG74's Avatar
Car: 91' RS CAMARO
Engine: 305 V8
Hope it helps!
IS THIS FOR 91 CAMARO??? AWESOME
Old Aug 27, 2015 | 09:47 AM
SKIDOG74's Avatar
Car: 91' RS CAMARO
Engine: 305 V8
SOOO.. ON CONNECTOR #2 (LEFT SIDE), #3, 7, 11, AND 12 ARE NOT WORKING.
Old Aug 27, 2015 | 12:23 PM
podiatra's Avatar
Engine: 350 swap
The pic is from a 1986 irocz
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
