Pull down hatch 1987 camaro HELP
Old Jul 22, 2015 | 02:15 PM
1987CMaro's Avatar
Car: 1987 Camaro Coupe
Engine: 350Ci 5.7
Hey guys I'm trying to find out what wire (red/white) kind of thing activates the hatch motor to pull down the trunk. I believe I may have cut it when I was swapping engines. Thanks!
Old Jul 22, 2015 | 06:07 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Pull down hatch 1987 camaro HELP
First off make sure you are getting power from the red wire with white stripe coming from the bundle on the driver's side of the car in the trunk. It should be always hot. If you aren't, then check the fuse and if that's not blown then you'll have to start figuring out where the power is dropping out.
If you are getting power at the red/wht wire, then it will be a problem in the wires right where the hatch is (the only external inputs to the hatch area are power and the hatch pop solenoid wire). I can look at my service manual's wiring diagram once I get off work, but if you are able to verify the red/wht wire having power it would be helpful.
Old Sep 21, 2015 | 04:17 PM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
So I just bought a camaro 87 vert and the tonneau switch does not work. I also checked the pull down motor and there a lot of cut cables 😧 so I need help rewiring the truck pull down to see if that will fix the tonneau switch
Old Jan 4, 2017 | 10:08 PM
1987CMaro's Avatar
Engine: 350Ci 5.7
Very late response but mine for what ever reason just crapped itself and the latch didnt want to come up to grab the trunk to pull down. So all I did is disconnect the battery, attach it again then push with a screwdriver on the latch and the trunk motor started humming and it worked. Nothing was wrong just messed up somehow...
Old Jan 5, 2017 | 12:46 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
This is the TECH ARTICLE that I posted here on TGO a LONG time ago. It will help you diagnose and repair your pull-down unit.
https://www.thirdgen.org/tech/hatchpulldown.pdf
Yes I still sell all the parts to repair these 86-87, 88-91 and 91.5-92 pull-down units. Lots of other interesting topics covered in the TECH ARTICLES section of Thirdgen.org.
Lon Salgren
Old Jan 9, 2017 | 02:07 PM
OrangeBird's Avatar
Car: 1989 Firebird
Ok , I gotta admit to not being any kinds of rocket scientist , so , can anybody here tell me which step of the procedure "replace engine" includes "mess with trunk wiring" ?
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
