Coolant Temp Gauge Not Working Before and After LS swap
Okay my Coolant gauge in the 85 z did not work before we ls swapped it, and it still does not. We have the 98 coolant temp sensor and the PCM has a good reading of the engine temp verified by HPTuners.
So theres got to be an issue with just the gauge, anyway to trouble shoot it by taking the cluster apart ( common issues? ) or a way to purchase a gauge by itself, couldn't seem to find any on the 'bay...
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temper Tantrum
The pinned below zero is consistent with a broken wire in the circuit.
With the engine OFF, but the key in the RUN position, ground the sender wire, then look at the temp gage.
What does the gage do when that wire is grounded?
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is In The Air
Happy Racing !
Ghettobird52
Jul 5, 2024 11:18 PM
