how do i get the dash off?
Old Dec 19, 2001 | 01:48 PM
LastHopeRS's Avatar
i need to get the dash off for a group of reasons...my gauges, my speakers, my vents....but i am not sure how to do. i heard it was just the tiny bolt scews that you see and nothing else...but i wanted to make sure before i start fiddling around. how many screws are there exactly...and where might i locate them. thank yous in advance.
Old Dec 19, 2001 | 01:58 PM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
i guess your working on a 3rd gen camaro, so it should be pretty easy.
First, with the speakers, you need to take the dash top off.
There should be some (i think 5/16) hex head screws just under the the overhang. Take those out. There are also 4 (either hex head or phillips head) screws by the defroster vents in the middle. After you get them all out, it just lifts up and out (just be careful, a bit of padding is somtimes under it).
That will give you access to the speakers.
For the gauges, you need some torx screwdrivers. Just take out the torx screws around the guage cover, and it will come right off. After that you need the (5/16?) nut driver to take out some more hex head screws around the clear plastic cover. The only other peice in there would be the black metal black outs that reflects the light back toward the gauges. A few more screws and thats out too, leaving you access to just the guages, and the 20 or so little light bulbs behind the guages. AT least thats what i get with my '88 camaro.
to put it back together just do the opposite.
Joker
Old Dec 19, 2001 | 02:01 PM
LastHopeRS's Avatar
thanks joker! thats what i like....quick responses, and intricate detail....now i can go get started on this job in the freezing jersey weather. thanks again.
Old Dec 19, 2001 | 06:22 PM
Tad's Avatar
Tad
Hex screws
The hex screws he is talking about will be a 7mm and the trox screwa should be a t-10 or t-15.
TAD
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
