can someone direct me to a resistor
Old Oct 2, 2015 | 09:44 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
What resistor are you using to fix an 88 tpi tach? Where? link? for the part
i appreciate it
Old Oct 5, 2015 | 03:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Piece Of Resistance
It depends on how far the other components have changed from their specifications.
There is circuitry in the dash near the tach.
It’s contained on a small plug-in PCB or integrated in the main board.
On or near the PCB you’ll see a capacitor, replace it.
Also on the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing !
You Know You’ve “Arrived” When Bikers Rev Their Engines When They’re Beside You
Gray Ghost 8991
Mar 13, 2016 01:16 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
L98GTA87
Oct 14, 2015 08:35 PM
L98GTA87
Oct 3, 2015 11:13 PM
L98GTA87
Exterior Parts Wanted
Oct 3, 2015 06:14 PM
