What is this purple wire?
Old Oct 3, 2015 | 05:32 PM
Thornburg's Avatar
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Howdy all,
So on my 1985 IROC 5.0L TPI, there is this purple wire coming out of the wire harness that runs out of the firewall just above/behind the brake booster on driver side, and the P/O put some kind of jumper on the factory plug, to close the loop. From what I found in the wiring pages is that purple is blower motor. Funny thing is my single coolant fan runs constant, so not sure if they have anything to do with each other or not...
Old Oct 3, 2015 | 09:26 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: What is this purple wire?
If you search C100, you'll probably figure it out.
That's the service manual number for the driver side wiring connector.
https://www.thirdgen.org/forums/v6/454985-stumped.html Post 11 has a diag. that says purple goes to Starting system, or Wiper washer.
Owning the service manuals to your car is a really good idea.
Old Oct 3, 2015 | 10:11 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
only purple wire on that side that I know of is the starter wire. It's not supposed to have a connector on it like that though. pull the jumper and if the starter doesn't do anything then that's it. Starter wires is a 12ga (possibly 10ga) wire
Old Oct 3, 2015 | 10:12 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I guess the advantage to that jumper if it is the starter wire, if you pull it, then likely no one is going to steal your ride. They'll think it's something more complicated to get it to run lol
amargari
Nov 10, 2015 02:09 PM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
leighgrils
Oct 9, 2015 09:38 PM
tommy z-28
Oct 6, 2015 10:58 PM
FormulasOnly
Sep 10, 2015 09:07 PM
