Help with pop up headlights!!!!!
Old Oct 11, 2015 | 11:23 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
Hi. My left side headlight will raise, but will not lower unless I manually crank it down. Does this sound like an electrical problem or does it probably need rebuilt? It is a 1986 Trans-Am with a little over 100,000 miles and never driven in winter with very little night time driving. Thanks!!
Old Oct 15, 2015 | 11:37 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Help with pop up headlights!!!!!
Likely the little plastic discs in the motor housing need to be replaced. You can get them from top-downsolutions or make your own. I bought a foot of 1/2 inch Delrin and cut pieces off to make the discs. Need a little sanding to fit but cost almost nothing. Do both sides while you're at it.
Old Oct 15, 2015 | 09:26 PM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Even if there is no motor noise? The driver side doesn't try to close or anything.....but it manually goes down very easy.....that is why I was hoping it was an electrical problem??? Going to look at it tomorrow. Thanks Base91!
Randomtask2
Oct 16, 2015 07:13 PM
72SSboy
Oct 16, 2015 03:27 PM
xaftmx
Oct 15, 2015 02:33 PM
st.evel07
Oct 13, 2015 07:54 PM
firechiken47
Oct 10, 2015 06:16 PM
