name that sound!!
Old Oct 10, 2015 | 08:09 PM
xaftmx's Avatar
Car: 1987 firebird 305 carbd
name that sound!!
Hello All, I am putting together a 305, I did not tear it apart, replaced the intake mf, carb, dizzy, ripped out the smog and emission crap out of a 87 firebird. dialing it in, but I hear a bad sound at idle,, rev it goes away,, idle back down,, bad noise. almost like a socket in the upper end bouncing off the rods.. (NO there is NOT a socket in there) any thoughts???
File Type: avi
Old Oct 11, 2015 | 11:21 AM
Vader's Avatar
Re: name that sound!!
Does that happen with all the belt drives removed?
Old Oct 12, 2015 | 06:54 AM
xaftmx's Avatar
I did not try that,, ill have to get the belts off and fire it up, wont be running long though with the water pump disconnected. long enough though to see. I was thinking rod knock,, like i said throttle up and it goes away, but on idle sounds like a socket bouncing around in the intake cavity.
Old Oct 15, 2015 | 02:33 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
You might have a lifter struggling to "pump up" at idle and one of your rockers is slapping the top of your valve, but when you rev it up then the lifter pumps up and brings that rocker back into adjustment. Just a thought....
EvilMunky707
Nov 30, 2015 03:00 PM
budowski
Carburetors
Oct 10, 2015 03:28 PM
lakeffect2
Oct 7, 2015 10:40 PM
soarestransam
Oct 6, 2015 10:44 PM
3rd gen money
Oct 5, 2015 08:31 PM
