305 to 383 serpentine belt woes
Old Oct 3, 2015 | 08:26 PM
3rd gen money's Avatar
Car: 1992 camaro rs
Engine: 383 stroker
hope this hasn't been posted before. On the 383 swap on my 92 rs, I am using the pulley brackets from the 305. But now it looks like my serpentine belt is much too short. Even if I remove the smog pump pulley it is still too short. What size belt do I need?
Old Oct 3, 2015 | 09:42 PM
Gray Ghost 8991's Avatar
Car: 1991 Camaro RS
Engine: 355 TPI
Transmission: 700R4 or 4L60
Re: 305 to 383 serpentine belt woes
You could try a few belts for 350s and see if that works for you, if you have some good relations with a parts store you could test fit a few belts. And this will sound stupid but make sure you've got your belt routed right. I've had a time with serpentine belts before that's why I say that
Old Oct 3, 2015 | 10:28 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
There should be no difference from 305 to 383 for the accessories. Are you sure you bolted them up in the correct spot when removed from the 305?
Old Oct 3, 2015 | 11:12 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
I agree. there shouldn't be any difference.
for the belt, any good part store should just be able to measure the width and length and style and match you for what ever you need. so if you need it x amount shorter...... it should be a breeze... if not, your at the wrong part store. I friggen hate when you go to a part store now and they ask for a vin# ridiculous. what a joke.
anyways, make sure the belt is on the right way... if the pulley is flat, the back of the belt rides there. if the pulley has grooves, the inside of the belt rides there.
Old Oct 4, 2015 | 08:04 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Originally Posted by 3rd gen money
... my 92 rs, ...serpentine belt is much too short.
There is a "long" belt routing and a "short" one. The 89-92 use the "short" routing with a 94.5" belt, and I suspect you installed the belt for the longer 98" belt... Try installing using the later method, and I bet it works. Afterall, the belt worked before.
Here I posted this:
Originally Posted by MoJoe
There's two ways to route the belt... short vs long. Belt lengths from AdvanceAutoParts
98.03" = Air - crank - water pump - power steering (88), or...
94.50" = Air - water pump - crank - power steering (89-92) as see in the previous pictures.
Thank to SEThirdGen for the diagrams (88 vs 89-92):
Old Oct 4, 2015 | 09:59 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
If you route it wrong the water pump will spin the wrong way.
Old Oct 4, 2015 | 12:43 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Wrong.
- A V-belt water pump turns the same direction as the crank, and is a "normal" rotation pump.
- Both serpentine belt routings turn the water pump the same way, which is opposite of the crank, and is called a "reverse rotation" pump. The only difference in the routings is the length of belt.
Old Oct 4, 2015 | 12:56 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
if you have a flat pulley, then the flat part of the belt rides against it... if it has grooves, the grooved side rides against it... as long as you do this, it will turn the proper direction regardless of what kind of screwy belt routing scheme you come up with..
Old Oct 4, 2015 | 06:32 PM
ex-x-fire's Avatar
First, verify belt routing.
Old Oct 5, 2015 | 08:31 PM
Car: 1992 camaro rs
Engine: 383 stroker
Thanks all. I was getting really frustrated trying to put on a short belt in the long belt pattern. I'll be saving that picture.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
bigjay89gta
Oct 15, 2015 08:04 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
92projectcamaro
Sep 29, 2015 07:07 PM
