1988 firebird formula 5.0 tbi timing issue
Old Oct 11, 2015 | 08:19 AM
Randomtask2's Avatar
Car: 1992 Pontiac Firebird Formula
Engine: 5.0 305 tpi
Transmission: T5 (5 Speed) lol
Axle/Gears: stock posi
So I had to replace the distributor in it. And upon putting the new distributor in I hand cranked the engine over to cylinder 1 on the compression stroke. Timed it with what the engine liked, advanced it quite a lot until it is most responsive. It runs very nice.But the downside. Now it idle surges till it dies out. And upon hard acceleration. Makes a rattling noise now. Don't lf it's spark knock. I've never heard spark knock before.Never had any running issues prior. So I don't have a ton of experience with Timing. Distributors were on the way out as I went to college. So would anyone have any idea. Is this a form of spark knock. Because I am running 87 octane. I would hate to turn the timing down because it's running so go good and responsive. And it's advanced quite past the timing spec. So if anyone has any information. It would help greatly.
Old Oct 11, 2015 | 08:45 AM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Re: 1988 firebird formula 5.0 tbi timing issue
Did you mark the direction the button was pointing when you removed the dizzy?
Old Oct 11, 2015 | 08:49 AM
Engine: 5.0 305 tpi
Your talking about the position of the rotor? Yes I couldn't get it to line up where the old rotor was at. It was a 1/4 position off where the rotor originally was with the new distrubutor. That's why I positioned it at cylinder number 1 on the compression stroke. Because I knew the timing would be off.
Old Oct 11, 2015 | 08:50 AM
Engine: 5.0 305 tpi
But I don't believe the timing is off with how good it's running. That's what's so confusing. I could have the timing too advanced. I'm not sure.
Old Oct 11, 2015 | 02:21 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Did you disconnect the EST wire before setting your timing, clear the code, and then restart?
Old Oct 11, 2015 | 02:46 PM
Engine: 5.0 305 tpi
No I didn't. I had both connectors plugged back in the back of the distrubutor. Any info for me. On how to proceed from here.
Old Oct 11, 2015 | 05:58 PM
antares57's Avatar
Look at response #5 on this thread.
https://www.thirdgen.org/forums/tbi/...lp-timing.html
Old Oct 11, 2015 | 08:07 PM
Engine: 5.0 305 tpi
The last car I timed was a olds rocket 350. I'm out of the loop. Well hopefully because I didn't do that Initially. It will work just fine. Thank you for real. Learn from my mistakes. Lol I will let you know how it goes.
Old Oct 16, 2015 | 04:06 PM
Engine: 5.0 305 tpi
Your not going to belive the resolution to the situation. My egr valve that's brand new stopped working. Once I unplugged it and blocked it off the idle no longer spikes. And I followed his instruction. And it worked just fine. She's running tip top supreme. Thank you for your reccomendation to look at the previous thread.
Old Oct 16, 2015 | 07:13 PM
antares57's Avatar
Good to hear it, enjoy!
bbsr72
Apr 2, 2016 09:12 AM
Damon
Sep 26, 2015 04:29 PM
wstephan96
Sep 25, 2015 04:28 PM
steimel94
Sep 23, 2015 12:48 AM
MartinD
Sep 22, 2015 02:27 PM
