92 Camaro Heritage Edition lost Keys
Old Oct 24, 2015 | 05:07 AM
Samsalt824's Avatar
Car: 1992 Camaro Heritage Edition
Engine: V8 305
Hey guys. Sorry if I'm reposting an already made thread. The search option on my phone is messed up and I don't have a PC at the moment.
I have a 92 Camaro RS Heritage Edition V8 305 5-speed. It was converted to aa carb system. Fuelpump and radiator fan was wired to a switch. It also is wired to a push button start switch. So all I do it turn key all the way, then push the button to start (Sorry for stating the obvious)
I'm going through a hard time with money-back the moment and just need the car running so I can use it for work. I need to be able to start the car without having to turn the key and everything still work (lights, A/C, heat, radio, etc..) what's the best way to do this without paying for a new ignition switch, locksmith, etc..
Thanks in advance and sorry for repost.
I lost the keys (searched for about 3 weeks before I decided to take it further)
Old Oct 24, 2015 | 09:43 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: 92 Camaro Heritage Edition lost Keys
New lock cylinder will probably be cheaper than trying to use switches for all the circuits needed to jumper. You don't need a complete ignition switch, just the lock cylinder with a new key. HTH!
Old Nov 9, 2015 | 12:29 PM
Samsalt824's Avatar
Engine: V8 305
And if I got a new key with a random resistance through it wouldn't I have to get a locksmith to come reprogram the VATS? I want/need everything hooked to switches. So I'm just trying to figure out what needs to be done. I already have a push button for starter installed. I literally just need to bypass the ignition and i'll be able to do the rest with VATS.
cowansauto
Jan 30, 2022 05:06 PM
Gunner242
Dec 25, 2015 04:49 PM
Alex Fields
Oct 26, 2015 05:16 PM
killswitch_313
Interior Parts Wanted
Oct 24, 2015 11:53 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
