Yet another Autometer Speedo Question.
Old Nov 11, 2015 | 08:40 AM
toeman's Avatar
Ive searched a few threads about the speedo hook-up(and their was a lot of them) but I could not find a definitive answer. I don't want to fry my speedo by hooking it up incorectly, especially since it is from the Custom Shop.
Im running a carb so I removed the ECM and a whole bunch of wires from under hood. I still have the VSS Buffer box.
So what would the proper signal hook-up be? Is the VSS to ECM hook-up needed? Do I just connect the SIG wire from the Autometer gauge to the BRN/YEL wire(which says it is a 2000 PPM or use the GRN/BLK wire that would have lead to the original cluster(which is 4000 PPM).
Or can I just eleminate the whole buffer box also and go straight from the VSS itself, in which case I do no know what is the High Signal and the Low Signal?
Got some pics for reference
Attached Thumbnails Yet another Autometer Speedo Question.-speedo.jpg   Yet another Autometer Speedo Question.-autometerspeedo.png
Old Nov 16, 2015 | 05:10 PM
NINĹ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speed Reading
You didn’t provide the model# of the speedo so this info is generic.
You do not need to connect the wire you have ovaled.
It should work with the 4K sig.
The HI♦LO question will not apply if you are feeding from the VSS.
Happy Racing !
Short Tracks Can Sometimes Be The Longest Races
Old Nov 20, 2015 | 02:11 PM
toeman's Avatar
Re: Yet another Autometer Speedo Question.
Im guessing the model # 2650-1266-00. That is the only numbers on the paper it came with.
Old Nov 22, 2015 | 10:11 AM
Pocket's Avatar
Car: 91 Trans Am
Leave the buffer box in place. The 4000ppm signal from pin C to your old cluster is the generic for nearly every speedo, so hook it directly to the new gauge
Old Nov 23, 2015 | 11:44 AM
toeman's Avatar
usafirebird
Dec 21, 2015 01:49 PM
tbroherd
Nov 4, 2015 08:45 PM
johnson92
Oct 18, 2015 10:17 PM
Cleotiz
Oct 18, 2015 12:14 PM
MXCamaro
Oct 16, 2015 09:15 AM
