Bypassing all the Computer $hit
Old Dec 20, 2001 | 07:42 PM
WaSayBo?'s Avatar
I am swaping motors in my '86 Z-28. It has a stock 5.0L w/4 barrell carb. I am putting a 350 with carb. So I want to get rid of all the computer crap as possible. If it is possible to get rid of it all, than tell me how!! Thanks.
Old Dec 20, 2001 | 11:55 PM
SgtSkip's Avatar
Non cc carb and vacuum advance dist for sure. I'm sure there's other stuff...(technical term)
Old Dec 21, 2001 | 03:59 PM
MotorCityMuscle's Avatar
Why do you want to ditch all the computer setup? Because your car is mostly a track car or because someone told you that you should. Its actually a very good setup. Its easy to work with if you familiarize yourself with your car and it delivers excellent fuel economy and don't think you can't use a 350 with your computer. the carburetor doesn't care what engine is under it. It will compensate automatically to assure optimal air/fuel ratio.
Old Dec 21, 2001 | 05:37 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Also to help. The harness from the pass. side is your computer related crap. The driver's side hanress is the crap you need for the car to function ie. guages, starter, lights, etc.
I dumped my puter a couple of years ago and have never been happier with the car.
Old Dec 22, 2001 | 01:01 AM
SgtSkip's Avatar
I've run with both a non cc edelbrock and a cc quadrajet. After learning the system I like the computer setup better. It's really not hard to learn.
$750 L98
Feb 1, 2025 02:25 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
RS Reaper
Sep 27, 2015 07:04 PM
Damon
Sep 26, 2015 04:29 PM
Twinn Engines
Sep 25, 2015 06:27 AM
