turn signals
Old Dec 20, 2001 | 11:10 PM
madreman's Avatar
turn signals
ok. with my hazzard lights on, all light's work fine. including the side markers. key on, no turn signals on the inside or outside.
the switch in the column is ok,"i checked it on another rs " i checked all the bulbs . the fuse is ok," because the b/u lights work" , what else is there to check? . because the hazzard lights work fine, i would think there was not a short between the plug and the lights.
any help out there???????????/
oh yea................
89 rs 2.8
Old Dec 21, 2001 | 02:28 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Check the turn signal flasher. It is located on the fuse block. The hazard flashers use a seperate flasher.......
Old Dec 21, 2001 | 08:44 PM
madreman's Avatar
re...re... turn signals
i got a new flasher, and another switch. still no signals..
i'll keep trying, thanks for the reply.
Old Dec 21, 2001 | 11:48 PM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
Just a quick question: Did you replace the hazard flasher, the signal flasher, or both?
I had a heck of a time trying to find the "signal" flasher because the one on my '88 in the 'conveince center' was actually my hazard flasher. The turn signal flasher was on a seperate wire, hidden way up behind the guages. I went for a while just having to flash the supid things off and on myself.
joker
Old Dec 22, 2001 | 02:43 AM
madreman's Avatar
re. turn signals
awesome,bro
i read that some where and i was just looking up in there.
thanks alot...... now about that "fix-it ticket" i got yesterday.
anybody work at dmv?
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
