Wiper motor problem
Old Nov 23, 2015 | 08:34 AM
David Fite's Avatar
Car: 1986 IROC-Z
Wiper motor problem
Just got my 92 RS on Saturday and it has a few bugs to work out...
The wipers work, along with the washer fluid. The problem is the wipers are SLOW. Like maybe 1/2 or 1/3 of the normal speed of each setting. I put it on hi and it's slower than the low speed should be.
Is this something fixable or do I need a new wiper motor? Never had to work on a wiper motor in any vehicle I've owned.
Old Nov 30, 2015 | 05:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fite For Your Right▬▬▬▬▬And Left Wipers
Gain access to the module on the left side of the firewall in the wiper motor assembly.
The connectors you will be disconnecting is the 2 pin connector going to the motor, and the 1 pin connector going to ground.
Insert a voltmeter in line with the 2 pin connector
purple wire and ground for measurement #1.
Insert a voltmeter in line with the 1 pin connector
gray wire and ground for measurement #2.
Keep the wipers switch in the OFF position, and put the ignition key in the ACCY position.
What are the voltage measurements you observe when you have the voltmeter in line with those pins?
Happy Racing !
When Someone Merely Scrapes The Wall They Throw An Unnecessary Yellow Just To Close Us Up
Maeryk
Dec 8, 2017 01:18 PM
Camarokop
Mar 22, 2016 12:07 PM
blue86iroc
Exterior Parts for Sale
Dec 16, 2015 08:49 PM
1982firebird7
Nov 24, 2015 09:35 PM
eddie jr
Nov 22, 2015 08:47 AM
