radio wiring nightmare
Old Dec 2, 2015 | 09:48 AM
SteelheadBen's Avatar
Car: 1988 Camaro RS
Engine: 2.8L v6
Transmission: 700r4 stock?
Axle/Gears: peg leg one tire fire
so in the process of installing a newer radio, the previous owner installed an after market radio with wrong color wire leads. anyone reccomend a way to clean up this wiring a bit? never installed a radio before.. also I noticed a orange and white wire hanging below my dash on the passenger side.. what wite does this go to? thanks
Old Dec 2, 2015 | 09:57 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: radio wiring nightmare
Courtesy Lamps, Lighter. See upper left of diagram
Old Dec 2, 2015 | 11:07 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Those wires look like the correct colours for an aftermarket radio, I don't follow what you mean by the wrong wire colours.
There are diagrams in the car audio section of this site that should help you repair this.
I would suggest getting a repair harness from a local car audio shop to put it back to factory and then use a harness adapter to attach the new radio. I suggest this because it's common for people to want to upgrade as more features become available on new radios or as system upgrades dictate a new radio is needed. Much easier to use an adapter each time than cutting the wires shorter each time.
Old Dec 3, 2015 | 09:10 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Six gave you some good advice. Metra makes both harnesses for about $15 a piece.
Old Dec 6, 2015 | 12:09 PM
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
I would go to a junk yard, cut a radio connector off a newer GM car, get some Micro-Pack 100 series terminals, crimp them onto the stock wires, remove the old terminals from the junk yard connector, and put the newly crimped terminals into the connector.
JakeM.
Feb 16, 2016 06:42 PM
lee01
Exterior Parts for Sale
Dec 27, 2015 12:05 AM
lee01
Dec 21, 2015 08:05 AM
Djmathis123
Dec 3, 2015 08:14 PM
zero13
Dec 1, 2015 06:33 PM
