No Spark
Old Dec 11, 2015 | 05:59 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
No Spark
i have an 86, WS6, 5sp, trans am with a 305. it's completely stock. i bought it for $1,100 a couple years ago and drove it home then raced it around the neighborhood for a couple days and then parked it in my garage. i had to move it into my driveway to work on it but it would not start. i have determined that i'm getting NO SPARK. this may be my fault because i when i put the batter in, i accidentally shorted it out TWICE. damn that pissed me right off. it shorted into frame so i wasn't too worried UNTIL i tried to start it. poured in some gas and NOTHING. i had to push it out of the garage very carefully because i was by myself where it now sits waiting for help. i checked the fuses and the only one blown is the AC fuse. any suggestions on troubleshooting this thing would be greatly appreciated. THANKS!
Old Dec 11, 2015 | 06:30 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: No Spark
No spark at the plugs, or the distributor , or out of the coil?
Old Dec 11, 2015 | 06:52 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: No Spark
at the plugs. thanks!
where in texas? i moved to florida from Tx.
Old Dec 11, 2015 | 07:23 PM
antares57's Avatar
Re: No Spark
Put a test light between the coil and distributor to see whether the coil is putting out. If so, it's possibly your pick up coil or ICM. If not, your coil is bad or not getting any current. I travel in the San Antonio, Corpus Christi, Houston area.
Old Dec 11, 2015 | 08:37 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: No Spark
thanks, i'll check it tomorrow.
i'm very interested in finding out what really happened to the bikers in Waco. the cops are covering something up...
Old Feb 8, 2016 | 06:11 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: No Spark
the coil is in the distributer cap. how do you test it?
the ICM is good. i had it tested at Advanced Auto Parts.
is the pickup coil in the distributer? gotta check that next.
Old Feb 8, 2016 | 09:18 PM
antares57's Avatar
Re: No Spark
I posted test procedures on your ICM thread but that may not apply to your coil. They procedure should apply to your pick-up coil though if you want to go back and look at it.
L98GTA87
Jul 30, 2017 12:22 AM
GMan 3MT
South Central
Mar 19, 2016 08:17 PM
LarryD
Dec 10, 2015 02:33 PM
91 zeee
Nov 26, 2015 09:39 AM
L98GTA87
Nov 23, 2015 04:52 PM
