1986 rear window with brake light
Car: 1982 camaro berlinetta
Engine: 5.7 350 swap
Transmission: th350 swap
Axle/Gears: 26 spline 7.5 ring gear
I have 1982 camaro berlinetta and I needed a rear window asap and I bought a 86 window I want to know how I can wire my window brake light to work thanks in advance
Re: 1986 rear window with brake light
Camaro is relatively easy; unlike the Birds, Camaro has separate brake light & turn signal wiring.
Just splice it into your brake light wire. Easy place to find it is at the "Fisher body" connector, which is about right under the clutch pedal.
Chris Luongo
Aug 23, 2016 08:58 AM
crazynights
Nov 30, 2015 05:27 PM
joef2002
Nov 15, 2015 12:02 PM
