headlight wiring conformation
Old Dec 13, 2015 | 08:15 PM
dragonmas's Avatar
Car: 1987 Z28 Vert.
Engine: LG4: ENGINE, GAS, 8 CYL, 5.0L, 4BBL
Transmission: MD8: 4 SPEED AUTO THM700R4
Axle/Gears: GU2: AXLE, REAR 2.73 RATIO
Everything I have seen shows the attached hi/low stock plug wired as in the
drawing, but on my 87 z28 the ground and high beam is swapped. Could someone confirm whether mine is wired correctly or not?
Old Dec 14, 2015 | 07:41 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: headlight wiring conformation
Grab your test light or volt meter.
Ground to a bolt, probe the one you think is high-beam while your high-beams are on.
Question answered.
I have the adapters from Susquehanna somewhere for visual reference but I did the switch latter on . . .
Old Dec 14, 2015 | 02:08 PM
dragonmas's Avatar
Car: 1987 Z28 Vert.
I did the probe already and found that my ground and high beam is swapped as compared to the stock 4656 as shown in the drawing.
File Type: pdf
blacksunshine'91
Dec 16, 2015 10:57 AM
bubbaz28
Dec 15, 2015 07:01 AM
gnilson
Dec 9, 2015 12:39 PM
kirkcomer
Nov 28, 2015 05:10 PM
sgp0511
Nov 15, 2015 07:14 PM
